Well, an accelerometer can only measure acceleration in different axes. If it moves at a constant speed in a constant direction (linear vector), the acceleration is zero. So you can only measure changes in velocity and calculate a change in position from this by integration, for example, whereby drift effects must of course be taken into account.
But a velocity (speed) cannot be derived from this.
Does it answer your question?
/Peter
