rehanar
interrupt generation problem during CTRL_REG3 setting in AIS328DQ
Posted on November 14, 2013 at 08:34
The accelerometer was generating the interrupt when the value of CTRL REG 3 was  set to 0x80. But AS CHANGED TO 0x84 to check the latch interrupt request there is no more interruppt generation. Can anyone provide help on this
rehanar
rehanarAuthor
Posted on November 18, 2013 at 05:36
Problem Solved!! It was due to the level of threshold below gravity level.
Above gravity level the interrupt is generated. Just a technical misunderstanding.
