sam239955
Apr 24, 2012 1:38 PM UTC
iNEMO 2.x Project in Keil µVision
Posted on April 24, 2012 at 15:38
ist their any iNemo Project already ported in KEIL ?
I'm searching for a solution to use the IAR Project in Keil but I always failing when i trying it by my self.
with regards
Sam
    Andrew Neil
    May 23, 2012 11:29 PM UTC
    Posted on May 24, 2012 at 01:29
    Have you been able to build any of the ''plain vanilla'' STM32 example projects - eg, for a Discovery board, and/or one of the DevKits?
    Perhaps it would be easier to start from there, and gradually bring-in the iNEMO bits...?
    It would show you how to set-up a project for Keil;  and you could then compare it against the IAR stuff - might give  a better idea of where you're going wrong...?
    Cross post:
    http://www.keil.com/forum/20905
