Jan 30, 2026 2:05 PM UTC
ims330dlc Gyro signals
Hi
Does anyone know how to stabilize the gyroscope and accelerometer signals. I am getting signals back but I am trying to move a radio button on a bullseye and can't seem to smooth out the signal. I am using I2C communications.
Apr 21, 2026 1:24 PM UTC
Have look at:
MotionAC
MotionMC
MotionGR
MotionFX
There are other Motion* products - it will depend on your precise needs.
Federica Bossi
Jun 15, 2026 8:28 AM UTC
Hi ​@fredschoville
I would recommend calibrating the IMU first and then applying sensor fusion, as suggested by ​@codebuk , and filtering, rather than using the raw accelerometer/gyroscope data directly. A complementary filter, together with gyro bias compensation, a small deadband, and a fixed sampling rate, usually helps reduce jitter significantly. In most cases, I2C is not the main issue unless the timing or reads are inconsistent.
