IIS3DWB10IS / STEVAL-MKI253A: WHO_AM_I returns 0x00 over SPI, while IIS3DWB works on the same setup
- 0 replies
- 3 views
I cannot obtain a valid register response from our new STEVAL-MKI253A board (IIS3DWB10IS). WHO_AM_I consistently returns 0x00 instead of the expected 0x50.
As a comparison, our STEVAL-MKI208V1 board (IIS3DWB) returns the correct WHO_AM_I value, 0x7B, using the same identification firmware, host board, adapter and ribbon cable. Only one sensor board is connected at a time.
Our setup is:
Host: P-NUCLEO-WB55.
VDD and VDDIO: 3.3 V, with a common GND.
Four-wire SPI, 8-bit transfers, MSB first, CS active low.
Both SPI mode 0 and mode 3 tested at approximately 500 kHz.
TCK/DBG1 connected directly to GND.
We have checked continuity between the adapter and the sensor board’s J1 connector for the SPI signals, power and GND.
We have also tested ST’s iis3dwb10is_read_data.c example, adapted to the STM32WB55, using the official IIS3DWB10IS register driver. The new board still returns 0x00.
Are there any additional board connections, interface settings or startup requirements needed before reading WHO_AM_I?
