IIS3DHHC sensor and (Extended) Kalman Filter (EKF)
Hi, I try to use IIS3DHHC as a simple inclinometer. I learnt that to get stable readings it may be a good idea to process raw data using Extended Kalman Filter (EKF). Some ST demonstrations available on YT mention that as well, but I found no source code.
I have tested several solutions found on Github but so far I found no good EKF implementation, preferably based on CMSIS-DSP or Eigen3 libs.
Could anyone advise?
A similar question was asked exactly 10 years ago here but it has not been answered yet.
