I3G4250D Read the temperature
  • June 13, 2024
  • 1948 views
I am using a I3G4250D gyroscope and would like read the temperature.
Currently, I read 246 (in decimal) in my register 0x26.
In two's complement, it is equivalent to -9.
Then I have to multiply by -1 so -9 * -1 = 9°C (I am not sure)
But It is the summer, and 9°C for a measure of temperature is not possible. I read 10 times the datasheet but no one information to convert the data from register into °C.
Can you help me please ? It will be great to edit the datasheet to give a formule to transform the raw data in °C.
Tom
Federica Bossi
Hi @TomBr ,
You could try to check your code with our PID examples on github where you can find the temperature reading implementation.
TomBrAuthor
Unfortunately, in your github example, you get only the raw data of temperature and not the data processed...
