SANAN.1
I have calculated the threshold value by setting the offset voltage of 3.3V and the the reference voltage of 5v for the 12 bit adc of 1024 states. I calculated 1024/5=x/3.3v which equals approximately 716.8.
Can I know how can I set this value in terms of Force or Pressure?
Like the representation of this value in terms of force or pressure??
Eleon BORLINI
Hi @SANAN.1​ ,
I believe you should multiply the voltage value for the sensitivity (usually expressed in Pa/V or in N/V for an analogic pressure or force sensor), that is usually reported in the sensor datasheet.
By the way, which ST sensor (part number) are you using?
-Eleon
SANAN.1
SANAN.1Author
I am using Piezo Sensor to get the Hpatic Feedback
SANAN.1
SANAN.1Author
Haptic*
