SMeht.1
I am looking to make audio circuit
I am looking to make audio circuit. I need suggestion for microphone followed by noise cancellation ICs.
Any help will be appreciated.
Sudhanshu.
Eleon BORLINI
Hi @SMeht.1​ , you basically need a tool (analog or digital based) to implement an active noise cancellation IC with a MEMS microphone, right? I suggest you to start from the Bluecoin kit design for the HW schematic and layout, and on the FP-AUD-SMARTMIC1 C libraries if you are starting from scratch. Regards
SMeht.1
SMeht.1Author
We want to understand MEMS better. Can someone from ST visit us. Sudhanshu Mehta Staff Engineer, R&D Stryker Stryker Global Technology Center, Tower-II, 8th Floor, Vatika Business Park, Sohna Road, Sector 49, Gurgaon -122002, India P +91-124-4850 965 C +91-9953930827 sudhanshu.mehta@stryker.com www.stryker.com<>
Eleon BORLINI
Hi @SMeht.1​ , thanks for the invitation and the interest :) Are you specifically interest in MEMS microphone for your application on in ST MEMS sensors in general and/or for other applications (accelerometer, gyroscope, environgmental sensors?) Regards
SMeht.1
SMeht.1Author
Hello Eleon,
Yes I am interested only in Mems.
I was looking on ST resources. Please validate my research. I need very good quality sound and I want to remove noise from that. (If your audio processor removes noise itself, that will be good as well.)
I found following combination
1) STEVAL-MKI126V3 (ST Smart Voice)
2) STEVAL-MKI129V3 (Mems coupan)
3) STEVAL-MKI138V1 (ST audio Hub) // I feel this is required for programming audio processor STA321MP only?
Question 1: After Proof of concept, if we order STA321MP, we will get that pre-programmed or we need to program at production line?
Question 2: ST Smart Voice can give I2S output. At this I2S output, do I need another noise removing chip (may be some CODEC)? If yes, please suggest.
Question 3: My research above on ST MEMS is good for audio reception or not? i mean i need very good audio quality without noise.
If you suggest something else, please give full description.
Sudhanshu Mehta
+91-9953930827 (call me anytime)
SMeht.1
SMeht.1Author
Do we need anything else in for making above thing working.. I need I2S output.. Rest of things i have in place.. FYI i am looking to use WT32i bluegiga module for proof of concept.
SMeht.1
SMeht.1Author
Any suggestion will be appreciated..
SMeht.1
SMeht.1Author
I am interested in MEMS microphones
SMeht.1
SMeht.1Author
@Eleon BORLINI​  can you please help us on this?
Eleon BORLINI
Hi @SMeht.1​ , as I wrote before, the reference design for an active noise cancelling and, better, beam-forming app is the Bluecoin tool, aka STEVAL-BCNKT01V1 (the first one you mentioned in the comment here above). The other suggested evaluation tool is the X-NUCLEO-CCA02M2. Both them can be interfaced with the tool you suggested, the NUCLEO-F410RB, that acts as master board. You can find the FW libraries for the PDM to I2S conversion in the Middlewares folder of the function pack FP-AUD-SMARTMIC1.
I suggest you not to use the STEVAL-MKI126V3 / STEVAL-MKI138V1 and related SW, because they are nrnd products and are no more supported.
SMeht.1
SMeht.1Author
Hello @Eleon BORLINI​
Thanks for your reply.
As per your suggestion, i have started doing POC with STEVAL-BCNKT01V1 .
it works fine when i record sound on PC using USB.
My next action is to make it compatible with product. I want to take this audio over I2S and send this to bluegiga wt32i iwrap6 module.
I am getting challange in this.
i want to reduce following items of STEVAL-BCNKT01V1 module.
LRCLK (Word Select Clock) - 8.00 kHz
BCLK (Bit Clock) - 385 kHz
I can compile code. Can you suggest how to lower this. I am using STM32CubeFunctionPack_SMARTMIC1_V2.0.0.
other wise voice on other side of Bluegiga module is cracking.
Sudhanshu Mehta
