Sprem.1
Jul 27, 2021 10:52 AM UTC
How to read WHO_AM_I register value read in LSM6DSOX?
I am trying to read the WHO_AM_I register in LSM6DSOX in that register value is (0Fh) and fixed value is (6Ch) but I am getting 0x00 I don't why can you help me regarding this
Peter BENSCH
Peter BENSCHBest answer
Jul 27, 2021 2:10 PM UTC
You should know how Start_SPI_Transaction is implemented, so please check the transmitted address and the SPI lines for correct data transmission.
All information on initialisation, how to define functions for read and write transactions and integrating extra bits can be found at the Github site mentioned above.
Good luck!
/Peter
Peter BENSCH
Jul 27, 2021 12:48 PM UTC
Welcome, @Sprem.1​, to the community!
Do you know e.g. our Standard C Drivers on Github, where you will find two functions (lsm6dsox_id_get, lsm6dsox_device_id_get) to read the WHO_AM_I register?
Are you able to read other register values?
Regards,
/Peter
Sprem.1
Sprem.1Author
Jul 27, 2021 1:48 PM UTC
Thank you so much @Peter BENSCH for your reply
what we are trying to do is connecting with the texas microcontroller and lsm6dsox sensor in that for the initial step we are reading WHO_AM_I register
txBuffer[0] =0x0F | 0x80;//WHO_AM_I register address
txBuffer[1]=0x00;
Start_SPI_Transaction (txBuffer,2,rxBuffer,2);
output[0]=rxBuffer[1];
From this, in Rx buffer, we should get (0x6C) fixed value (datasheet) but we are getting 0x00 I don't why?
I also have another doubt to configure the lsm6dsox sensor we need to follow any configuration process? can you help me regarding this
Peter BENSCH
Good luck!
/Peter
Sprem.1
Sprem.1Author
Aug 3, 2021 11:04 AM UTC
Finally, we got output from WHO_AM_I register it is connection issue
Peter Bensch, I have another doubt we are trying to read high-performance mode in lsm6dsox we have any procedure to access the register
we have tried according to the datasheet but we getting is 0 in the OUTX_L_A register can you help me regarding this issue
Peter BENSCH
Aug 4, 2021 7:43 AM UTC
The original question has been answered. Therefore it makes sense to create a new thread for further problems.
/Peter
Sprem.1
Sprem.1Author
Aug 9, 2021 3:50 AM UTC
Thank you so much peter
