CZorg.1
Jun 22, 2022 2:11 AM UTC
How to read lis2hh12 Activity/Inactivity status over registers?
I set ACT_THS and ACT_DUR registers, so now the chip enters on low data rate mode (10 Hz) when no movement is detected. everything is fine to that point.
I don't have access to INT1 and INT2 pins physically so I need to read activity/inactiviy status by registers.
    Eleon BORLINI
    Eleon BORLINIBest answer
    Jun 24, 2022 2:57 PM UTC
    HI @CZorg.1​ ,
    You might poll the IA bit of this general interrupt status register (see datasheet, p.39):
    0693W00000NsiGrQAJ.pngYou'll clear the interrupt by reading this reg. This is a general purpose register, so you'll see here all the status of the interrupt you have set.
    -Eleon
    Eleon BORLINI
    HI @CZorg.1​ ,
    -Eleon
