Vkj.1
how to install mems libraries in cube ide?
i have installed the mems packages but not possible to extract the libraries for nucleos f446re board
niccolò
Hi @Vkj.1​ ,
if you installed correctly the mems package, you should be able to activate the mems you want to use in the main page of STM32cubeMX by selecting the components under "software packs"
then you generate a project and should be able to see the libraries along the other files
let me know if this helps
Niccolò
