Tiago F
How to connect STEVAL-STWINKT1B to pc to monitor and save data?
Hi.
I bought a STEVAL-STWINKT1B board, however I try to perform all the steps to be able to see the data collected by the sensors and I can't because I can't understand what I need to do. I just wanted to connect this board via usb to my pc , monitoring data and saving it to a file (eg .txt) or saving the data to the sd card.
Can someone help me, please?
Thank you.
    JWu.12
    JWu.12Best answer
    January 5, 2022
    Hi @Tiago F​ , the STSW-STWINKT01 firmware package and in particular the HSDatalog example of the FP-SNS-DATALOG1 software package allows you to save data from any combination of sensors and microphones configured up to their maximum sampling rate. Sensor data are stored on a micro SD Card, SDHC (Secure Digital High Capacity) formatted with the FAT32 file system, or can be streamed to a PC via USB.
    You can find the details in this document, p.26 and 27:
    https://www.st.com/resource/en/user_manual/dm00736296-how-to-use-the-stevalstwinkt1b-sensortile-wireless-industrial-node-for-condition-monitoring-and-predictive-maintenance-applications-stmicroelectronics.pdf
    Here there is a tutorial on how to program the FP-SNS-DATALOG1 on the STWIN with STM32CubeProgrammer
    https://www.youtube.com/watch?v=Nd1EOjHfyN4
    JWu.12
    JWu.12Best answer
    January 5, 2022
    Tiago F
    Tiago FAuthor
    Hello @JWu.12​ ,
    Thank you very much!!
    Best regards.
