Andrey Sedelnikov
How to configure the sample rate for the acceleration sensor in STEVAL-STLKT01V1 ?
  • February 26, 2018
  • 8 replies
  • 2077 views
Posted on February 26, 2018 at 09:17
I'm trying to read out the accelerator values using
STEVAL-STLKT01V1, on iOS. Is there any possibility to set the sample rate of the sensor?
Note: this post was migrated and contained many threaded conversations, some content may be missing.
Posted on February 26, 2018 at 09:50
What FW and application on iOS are you using?
Andrey Sedelnikov
Posted on February 26, 2018 at 10:00
When I connect to the sensor using ST App the sensor is found as BM2V220. I do not see any other possibility to read out the FW version. I've got sensors from my customer for whom I should write an iOS app so I do not know other details about the sensor HW. I'm trying to create iOS app using BlueSTSDK_iOS.
Posted on February 26, 2018 at 10:55
The BM2V220 is shortcut for
https://my.st.com/content/my_st_com/en/products/embedded-software/mems-and-sensors-software/open-mems/bluemicrosystem2.html
 software.
It is obsolete and it has been replace d by
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-ode-function-pack-sw/fp-sns-allmems1.html
But unfortunately none of these FW allow to set the sample rate of the sensor. You would have to modify the FW and implement a command for it.
