sp ra
January 9, 2019
How to change working modes of VL53l0X at runtime
I am using ST s API(VL53L0X TOF Sensor) and i have a doubt regarding the change in ranging modes at run time,For my application i want the sensor to work in HIGH ACCURACY mode first and after a time it has to work on FAST MODE and again back to HIGH ACCURACY mode.Is it possible ?? if yes how can i implement it on the application
Thank you
John E KVAM
The only real difference between high-speed and high-accuracy is the timing budget.
Just try changing that, knowing the time will not take effect until the next range.
Technically you really should do a stop, change the timing budget and start again, but the kludge should work.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
