Welcome, @g mcclean, to the community!
The package is not yet integrated into the STM32CubeIDE. The easiest way is to work with it directly and try out the included projects first:
- manually unpack into (for Windows: a not too deep) path of your choice
- find your preferred project for your board
- to be on the safe side, make a copy of that project in the same directory level (this allows you to compare what has changed later or to copy it back).
- open the original project directly at its location, for the STM32CubeIDE start the file .project, all library references are already included in the package
If you need the drivers and middlewares in your own projects, you should add them manually.
Does it answer your question?
/Peter
