MOtt
Dec 6, 2019 10:21 PM UTC
How do I export the serial monitor output as a usable Excel file to plot the data with Excel?
I am using the STEVAL-IDP005V1 and the terminal emulator, Putty, to output sensor data to my PC. I would like to plot the FFT data using Excel like is mentioned in page 20 of the Quick Start Guide. I have tried using the Putty configuration manager to output the full session to a log, but when I convert the log to an Excel file, all columns of the data in the serial monitor output are all placed in the first column in Excel. If I were to try to plot the data using this format, I would have to separate all 2000+ data points manually into different columns to make a graph using Excel. Is there a way to have the output data placed in multiple columns like is mentioned in the quick start guide? (Pg. 20 of the STEVAL-BFA001V1B Getting started Guide)
    raptorhal2
    raptorhal2Best answer
    Lead
    Dec 7, 2019 3:07 AM UTC
    At this link:
    https://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/communication-and-connectivity-solution-eval-boards/steval-bfa001v1b.html#overview
    It says you have an L469 chip, an SWD ST-Link programming and debug interface, and gives links to firmware examples you can modify.
    Failing that, use a text editor to manually add commas as required to the Putty file.
    Cheers, Hal
    raptorhal2
    Lead
    Dec 7, 2019 1:01 AM UTC
    Program the STEVAL to output a comma character after each data variable, then import the file into Excel as a csv file.
    Cheers, Hal
    MOtt
    MOttAuthor
    Dec 7, 2019 2:03 AM UTC
    Where can I find information on programming it to output a comma after each data variable​?
    raptorhal2
    Lead
    At this link:
    Cheers, Hal
    MOtt
    MOttAuthor
    Dec 17, 2019 1:54 AM UTC
    Hi Hal,
    Thank you for this solution, I was able to use the STM32Cube IDE to modify the communications .c file of the condition monitoring SRV project and create a new .bin file that has comma separated values I could copy in paste into Excel using Putty's option to output a log as a .csv file.
