NAndr.1
Aug 16, 2020 9:48 PM UTC
How can I import patterns which I wrote for Steval MKI109V2 with MKI134V1 to MKI109V3 with MKI196V1?
I wrote some patterns for three-axis state machine based on MKI134V1. Now I need to import that patterns into six-axis state machine based on MKI196V1. I used standart button "load" but nothing worked. I can't find user manual with examples six-axis state machine like I found for three-axis . If you share this manual or help to solve my problem I'll be grateful.
P/S Sorry for my English
    niccolò
    Aug 18, 2020 1:55 PM UTC
    Hi @NAndr.1​ ,
    when you said you wrote the patterns for the three-axis state machine, do you mean you are trying to load a .fsm file in Unico?
    NAndr.1
    NAndr.1Author
    Aug 18, 2020 10:28 PM UTC
    Yes, I use Unico GUI for work.My three-axis patterns has ucf form. I used to load them in "Load /save congiruration" tab. I had understood thats patterns for 6-axis state machine has .fsm form. But maybe exist another way to "upgrade" old patterns and make them work with 6-axis?
    niccolò
    Aug 19, 2020 8:51 AM UTC
    I'm sorry, but the configuration files are too different to be used with both sensors.
    you can find some examples of Finite State Machines for the LSM6DSO (MKI196V1) here: https://github.com/STMicroelectronics/STMems_Finite_State_Machine/tree/master/lsm6dso
    and the application note that explains how to implement it here:
    https://www.st.com/resource/en/application_note/dm00537590-lsm6dso-finite-state-machine-stmicroelectronics.pdf
    may I ask you what does your pattern do?
