KChin.7
October 24, 2019
How can i Get Lower FFT step size for Higher ODR Values- STEVAL-IDP005V1 - Condition Monitoring?
In STEVAL-IDP005V1 - Condition Monitoring, I have set FFT_SIZE_MAX as 2048. Instead of ISM330DLC, i am using Higher ODR Acceleration sensor. As FFT step size( Delta f) is directly proportional to ODR, i am unable to get lower FFT step size( Like 0.5Hz) for higher ODR values.
Ozone
Principal
October 24, 2019
The size of 2048 was (is?) the maximal size implemented in ARM's DSP package the FFT code is obviously based on. I didn't check recently, though.
You might investigate alternative FFT implementations.
