Anil3
How can i change the of range of IMU sensor
Hi Everyone,
I am using STEVAL-MKI182V2 IMU sensor and can able to get the Euler angles of Yaw=360 degrees , Pitch= +- 180 degrees and Roll=+-90 degrees, now i want to get the Roll with range of +- 60 deg how can i get that range, please suggest me.
Thank you.
    KnarfB
    The roll angle in degree is a physical property of the sensor pose. What do you want to limit here?
    hth
    KnarfB
    Anil3
    Anil3Author
    Hi KnarfB,
    I want to limit the angle of rotation for Roll axis to +- 60 degrees instead of +-90 degrees
    Eleon BORLINI
    Hi @Anil​ ,
    I'm not sure I have caught the point... If you want to limit a rotation angle, you should act clamping your system at physical level, while if you want to convert a 0deg-90deg angle linearly into a 0deg-60deg angle you should do the relative proportion.
    -Eleon
