SG.4
Hello ST community Experts , MEMS mic + STM32f4xx evaluation board I am trying to stream PCM data serially on UART . Some issues please help?
Configurations :- STM32CubeMX M4-F446RE+ICS43432 mic
sysclk-168MHz HSE, DMA- circular,SPI2_RX ,half word
I2S2 - half duplex ,master receive mode 32KHz audio frequency
USART2 - 9600 B/s
PDM2PCM middleware use for conversion
1)Can Anyone suggest is there anything wrong with the configuration?
2) Now how do I acquire the PCM streaming data to print serially over UART?
3) And how I interface the BSP package before generating the code in the cubeMX
Thanks in advance.
Vangelis Fortounas
Hello
9600 bps is not adequate rate for this job
32khz sample rate with 16 bit samples need at least 640kbps rate .
SG.4
SG.4Author
Hi @Vangelis Fortounas​ ,
Appreciate your reply thank you .
ok will look into it.
Further of the question any ideas answers if you have any experience please support.
Vangelis Fortounas
Hello
I have no experience for audio over async serial transportation but i use serial ports.
UART can't send 16 bits and how the receiver will handle the situation that one byte is missing ? (everything is shifted and garbaged )
A "sync pattern" added every some words is fair solution for synchronization between transmitter and receiver but adds some data overhead.
if data integrity is crucial need a second layer tranportation protocol with packet counting , checksums, ACKs, resend, etc.
