DLapt
Get data from NUCLEO-F767ZI with Unicleo-GUI.
I have NUCLEO-F767ZI with plugged X-NUCLEO-IKS01A2 and some DIL24 evaluation sensors. Where can I get example firmware for NUCLEO-F767ZI to get data from DIL24 sensors with Unicleo-GUI?
Thank you!
    Eleon BORLINI
    Hi @DLapt​ , did you try to flash the X-CUBE-MEMS1 and launch Unicleo-GUI to check if it is working? Regards
    DLapt
    DLaptAuthor
    Yes, I use additional software "IKS01A2_DataLogTerminal", but after generating the code for Keil the main function is empty.
