E-John
g-sensor value on Z direction is negative when Z-axis is downwards?
  • June 27, 2022
  • 1344 views
Dear SIR,
I found that LSM6DSR got negative value when X-axis is upwards, got negative value when Y-axis is upwards.
Why only Z-direction got postivie value when Z is upwards?
That seems break the right-hand-rule direction. Is ther any reason for that?
Thanks.
    Eleon BORLINI
    Hi @E-John​ ,
    I believe this is just a matter of convention. The convention adopted is the one described in the datasheet, p.6. The arrows are indicating the value of the positive acceleration verse.
    -Eleon
    E-John
    E-JohnAuthor
    HI Eleon,
    By right-hand-rule, the value on z-axis arrows pointed should be positvie value. Here we got the opposed result.
    Just want to know what kind of convention make z-axis point to the negative acceleration value.
    Thanks.
    E-John
