s_wd8y9x
Function INEMO2_SDK_Connect
Posted on June 29, 2014 at 17:20
Morning, everyone,
I used a demonstration board STEVAL-MKI062V2. I wrote a small C++ program and want to get data from the sensor. It looks like, that some functions are not in the dll file (''iNEMO2_SDK.dll'') .The codes are:
typedef int (WINAPI *DLLPROC_CON)(LPCSTR);
DLLPROC_CON INEMO2_SDK_ConnectFunction;
INEMO2_SDK_ConnectFunction=(DLLPROC_CON)GetProcAddress(hinstDLL,''INEMO2_SDK_Connect'');
By debugging I found, the function pointer INEMO2_SDK_ConnectFunction did not get a value.
Can someone help me? Does the function INEMO2_SDK_Connect have another name? I read the text ''Wrapper in Visual Studio for the STEVAL-MKI062V1'' and wrote such codes.
Best regards
06.29.2014
    s_wd8y9x
    s_wd8y9xAuthor
    Posted on July 18, 2014 at 16:09
    I write a program under MATLAB. The demonstration board works very well now. The administrator can delete this text now. Thanks.
