Erenburg.Evgeny
FATFS and STM32CubeIDE
I generate the code for FATFS. But functions in user_diskio.c not populated.
for example
DRESULT USER_write (
	BYTE pdrv, /* Physical drive nmuber to identify the drive */
	const BYTE *buff, /* Data to be written */
	DWORD sector, /* Sector address in LBA */
	UINT count /* Number of sectors to write */
 /* USER CODE BEGIN WRITE */
 /* USER CODE HERE */
 return RES_OK;
 /* USER CODE END WRITE */
What should I set to populate these functions?
KnarfB
You are supposed to implement the backend yourself.
For a SD specific backend, there is sample code here: https://github.com/STMicroelectronics/STM32CubeF0/tree/master/Drivers/BSP/Adafruit_Shield
And the original FATFS authors docs: http://elm-chan.org/fsw/ff/00index_e.html
Erenburg.Evgeny
I see. Thank you. To implement myself - it's better be in IAR with simple and clear code.
KnarfB
Well. You sure have a specific backend for your design. FATFS is "just" a translation from file ops to block level IO. What is your target hardware?
