Darren Sherin
Enable accelerometer on iks01a2 board in i-cube-lrwan end node example
By default the temp, humidity and pressure are enabled in the end node example and i would like to enable the accelerometer in order to include the data in the payload being sent from the end node. How would i go about including the accelerometer code in this example. Adding the data to the payload and sending in out i can handle myself just dont know where to start to add accelerometer code and compile it. Using keil toolchain.
thx in advance.
