Difference in actual measured values for ASM330LHH ODR settings
We are operating ASM330LHH with ODR set at 3333Hz, but the actual measured output is about 3570Hz.
This is not stated in the specifications, but is this within the range of the specifications?
TDKBest answer
See here for a discussion on this topic.
Solved: ASM330LHH Frequency Measurement using the mother U... - STMicroelectronics Community
TDKBest answer
