GTS.1
May 7, 2020 5:55 AM UTC
Current consumption of LSM6DS3
I would like to know the current consumption of a LSM6DS3 with it's accelerometer and gyroscope running at 52 Hz and 104 Hz. The LSM6DS3 will be powered by a 2.8V source. Are there any official numbers or documents available for this?
    Eleon BORLINI
    Eleon BORLINIBest answer
    May 7, 2020 6:46 AM UTC
    Hi @GTS.1​ , I can share you some characterization (lab) data on 30 samples, for Vdd = 2.5V (so for 2.8V the current consumption will be a little bit higher):
    • Axl and gyro ODR = 52Hz
      • Low Power mode
    • High performance mode
    • Axl and gyro ODR = 104Hz
      • Low Power mode
    Eleon BORLINI
      • Low Power mode
      • Low Power mode
    GTS.1
    GTS.1Author
    May 13, 2020 11:15 AM UTC
    Thanks for the quick reply!
