KnarfB
CubeMX + X-CUBE-MEMS1 application generation for a "custom" board. Is there a way to replace the word custom when generating the code?
The generated code may contain hundreds of occurrences of custom*, CUSTOM* and some custom file+folder names. Renaming this afterwards is cumbersome, even when using tools. Moreover, this has to be done after each code re-generation. Are there means to enter the name of the board already in CubeMX?
Frank
