gandhi
Could not achive 3200Hz data rates for ADXL345 with Nucleo-L053R8
Posted on November 03, 2015 at 10:27
I'm planning to get 3200Hz data rates for ADXL345 sensor with Nucleo board. The SPI speed is 5MHz. And i initialized exactly as per the data sheet.
the initialization process is as below:
accelerometer.setPowerControl(0x00);
accelerometer.setDataFormatControl(0x0B);
accelerometer.setDataRate(ADXL345_3200HZ);
accelerometer.setPowerControl(0x08);
Here I'm using high baudrate.
Suggestions would be appreciated. Thank you.
