JDave.4
Conversion from Roll-Pitch-Yaw to Phi-Theta-Psi
The output of MotionDI algorithm is Roll and Pitch angles. How can I convert Roll-Pitch-Yaw to Phi-Theta-Psi? Thanks.
    JDave.4
    JDave.4Author
    Any idea?
    Hello, it is not clear what do you want to accomplish. What is your definition of the Phi-Theta-Psi and why you can't use roll and pitch.
    JDave.4
    JDave.4Author
    Indeed I would like to calculate the tilt angle for an inclinometer application.
    Please see the AN below:
    https://www.st.com/resource/en/application_note/an4509-tilt-measurement-using-a-lowg-3axis-accelerometer-stmicroelectronics.pdf
    Please see page 7 equation 6 and 7. But MotionDI output values at only one axis deviate from those when the sensor is tilted on both axes. How can I fix it?
