MFilo.1
May 13, 2021
Connectivity problems between SensorTile.box and Matlab
I'm trying to establish the connection between the SensorTile.box and Matlab. When I search for the Sensortile.box with the proper Matlab command, I can see the device but then, when I try connecting it, I get an error. I tried the same with a Sensortile (firmware: FP-SNS-ALLMEMS1_v3.1.0): it worked and the connection was robust. I thought about changing the SensorTile.box firmware (e.g. with the FP-SNS-ALLMEMS2 for the L4R9, and others) but I got the same error during the connection process. Can you suggest me a working firmware for this specific issue? How can i solve my problem? Thanks in advance.
    SZhou.11
    June 24, 2021
    Hi @MFilo.1​ , I am having the same issue with my SensorTile.Box. I was wondering if you were able to find a solution to this problem?
    Thank you
