RBAGU.1
Communication between SM32F401+iks01a3 and Unicleo it is no possible.
I am working with a SM32F401+iks01a3 and the x-cube-mems1 example Datalog_Terminal.
The program works correctly in the IDE and I can see the sensor values with the terminal application, but Unicleo doesn´t detect the nucleo board.
Many thanks.
DatalogTerminal only sends data to a terminal application. If you want to use Unicleo you need to program the STM32F401 with DatalogExtended firmware.
RBAGU.1
RBAGU.1Author
Many thanks.
