addast
Jul 31, 2020 1:56 PM UTC
Can I use lsm6ds33 tap detection without interrupt pins connected to MCU?
I'm planning to use lsm6ds33 for my project, but I don't have enough MCU pins for interrupt.
Can I use tap and double tap events without interrupt pins connected to MCU, just checking some registers few times a sec?
niccolò
niccolòBest answer
Aug 7, 2020 9:38 AM UTC
Hi @addast​ ,
yes, you can read the register TAP_SRC (1Ch) to check if the event you wait for has occurred or not, just like you would do with the interrupt pin available.
How often are you going to check for the event?
Niccolò
niccolò
niccolòBest answer
Hi @addast​ ,
Niccolò
addast
addastAuthor
Aug 7, 2020 9:55 AM UTC
10 times per second, maybe more.
niccolò
Aug 7, 2020 11:18 AM UTC
that should be fine, remember to check register INT_DUR2 (5Ah), for time constraints compatibility with your application.
