andrew dsouza
March 8, 2018
can anyone suggest gps sensor compatible with X-NUCLEO IDS01A5 expansion board?
Posted on March 08, 2018 at 08:17
    March 8, 2018
    Posted on March 08, 2018 at 13:57
    I haven't personally seen many GPS modules as Arduino shields (here is an example:
    https://www.u-blox.com/en/product/ea-cellular-and-positioning-shield
      ), but nothing limits you from buying an Arduino expansion board shaped protoboard and solder a GPS module on that. Here a is breadboard version:
    https://playground.arduino.cc/Tutorials/GPS
     . You could take the module and create your own expansion board. Custom board has the advantage that you wire the pins as you need and avoid conflicts before you power everything up.
    David
