Evelina CAMILLERI
blog.st.com
We’ve just announced the launch of a new sensor unit called SensorTile.box. It is a flexible IoT Plug and Play module to jumpstart sensor-to-cloud IoT applications.
Find out what you can do with the SensorTile.box by reading our blogpost at  https://blog.st.com/sensortile-box-sensor/
Grab yours to get started!
Follow this new topic! More to come ...
DWeis
June 18, 2019
I just got one sensorTile.box. How can I connect it to a PC (Window 10 based) for downloading sensor's data?
David
Eleon BORLINI
​Hi David, when you select an App from your smartphone, after the automatic downloading of the FW on the SensorTile.box you can select Start logging and then send you a mail with the datalog attached. You can also select the Data recorder app and that enables you to download of the data stream on your PC by USB cable or Bluetooth. Regards
DWeis
June 18, 2019
Thx
How and from where can I download to my PC the data rec app?
David Weisman
Co-founder & CEO
Eleon BORLINI
​You can download the app from here (STBLESensor). Regards
