Daniele Amato
Battery life STEVAL-STLKT01V1 SensorTile
Posted on April 04, 2018 at 12:09
I have the sensortile
development kit
, I wanted to test the battery life without soldering the sensortile to the cradle board, without using USB charge and with the accelerometer always active. Does anyone who has used this sensor have an idea of how long it lasts battery?
Daniele
#battery #steval-stlkt01v1 #sensortile #sensortile-kit #accelerometer #battery-charging #battery-life #test
Posted on April 05, 2018 at 12:57
Nobody will be able to give you exact answer.
The current consumption depends on many things (which IC are switched on, CPU clock, CPU sleep mode, firmware, ...)
Daniele Amato
Posted on April 11, 2018 at 11:52
Hi Miroslav,
I have not changed firmware, cpu clock or sleep mode from the default values. I have only activated on the board the acceleration sensor and a BLE connection with an Android device.
Daniele
