ASM330LHHXG1TR Top Marking Identification
Hello ST Support Team,
Could you please confirm the official top marking codes for the following four IMU devices?
ASM330LHHXTR
ASM330LHHXG1TR
ASM330LHBG1TR
ISM330DHCXTR
Based on the information I found, the top marking for ASM330LHHXTR is "LC", and the marking for ISM330DHCXTR appears to be "IR".
I also have a device that appears to have "G1" marked on its top surface (please see the attached photo). Could you confirm whether this marking corresponds to ASM330LHHXG1TR?
In addition, could you provide the official top marking codes for all four devices and explain how to distinguish them visually?
This is particularly important because we need to identify the versions rated for operation up to +125°C.
Thank you for your assistance.
Best regards
