AIS2DW12 normal functioning
Hi everyone,
I have run into some problems reading any data from the AIS2DW12 and I would like to know if anyone has had the same issue. I can read the Device ID through I2C but I am not able to read acceleration or temperature data. So my question is if by default everything is connected as should be using i2c mode(CS pin SET to vcc), should the accelerometer generate acceleration readings? I am reading the DRDY flag and its reading 0. All my acceleration registers are reading 0.
