Jul 30, 2023 9:16 AM UTC
Achieving < 1ug/√Hz at 1 Hz using ADXL355 module
Is there any way to achieve this desired noise sensitivity using the ADXL3555 accelerometer. Maybe using filter? Appreciate the help.
Peter BENSCH
Peter BENSCHBest answer
Jul 30, 2023 7:14 PM UTC
Welcome @shahriar19, to the community!
You took a slight wrong turn in your search for support for your MEMS sensor: STMicroelectronics also has such sensors in its range, but the ADXL3555 is not a product of STMicroelectronics, so it is unlikely that anyone here can help you.
Good luck! /Peter
Peter BENSCH
Good luck! /Peter
Jul 31, 2023 9:36 AM UTC
Thank you for your answer. Can you suggest any sensor that has noise sensitivity of < 2ug/√Hz at 1 Hz. The frequency range can be 1 to 100 Hz. Any suggestions will be appreciated.
