kimia23
Accelerometer sensor automatically compensate for temperature
the values of my accelerometer axes are affected by temperature changes and require calibration at each temperature.
What method should be used for compensation? How can Bias Drift and Scale Factor Drift be determined each time the temperature changes?
Andrew Neil
You haven't said what accelerometer you are using.
How to write your question to maximize your chances to find a solution
There should be temperature data in the datasheet?
kimia23
kimia23Author
I am using the LIS331 sensor and have attached the datasheet here.
Andrew Neil
So did you read the datasheet to find the temperature-related specification ?
It is your job as designer to study the datasheet ...
