jianxiong_1009
A terrible question when i use MP45DT02
Posted on August 16, 2014 at 06:03
Hi,I am Jesse
now,i will use MP45DT02 in my project
but i evaluated it in STM32F407-DISCOVERY,
i found a kind of terrible noise , it sounds like ''dot……dot……dot……'',especially female voice.
wish a solution
thank you very much
jianxiong_1009
Posted on August 22, 2014 at 11:45
I solved it.
I increased the RAM of the AUDIO-BUFFER
excellent mems-microphone!!
this is the point:
 /* Defines for the Audio recording process */
  #define RAM_BUFFER_SIZE         8000  /* 3Kbytes (1500 x 16 bit) as a RAM buffer size.
                                           More the size is higher, the recorded quality is better */
f23
Posted on June 09, 2015 at 19:20
Can you show me your code if you dont mind. Do you used PDM filter for the signal processing?
