Peter BENSCH
Peter BENSCHBest answer
Dec 4, 2023 10:22 AM UTC
Even if the STEVAL-STLKT01V1 is still marked as Active, you should probably no longer use it for new developments. It is based on BlueNRG-MS, which is already on NRND (Not Recommended for Ne Designs = product is in volume production only to support customers ongoing production).
/Peter
Peter BENSCH
/Peter
rdlAuthor
Dec 4, 2023 3:43 PM UTC
thanks for your suggest
