EGÜRL.1
Oct 6, 2020 6:11 PM UTC
What is my SPI communication error with SPSGRFC-868 module?
There is a problem using SPSGRFC-868. let me write my steps,
  • I generated 72Mhz/64 clock freq. for SPI
  • SPI working mode 0 (Clck idle low/ first clck edge)(I tried 4 mode extra.)
  • before loop SDN pin LOW
  • Before read-write Chipselect pin LOW, after that HIGH.
  • firstly I tried reading registers . the codes like that,
Write(0x01);
Write(0x94)  // any register
Dummy_data = Read(0);
               I run the code.(I look osilosscope and SPI signals as I wrote above.)
  • fristly Dummy_data becomes 0x52 20-30 times. after that Dummy_data becomes 0x00 finally Dummy_data becomes 0xFF
I try so much variation. Can u help me what is my fault?
