Jean DEMBEGA
Jun 12, 2017 3:05 PM UTC
What can I do to solve Data mistake on SPWF01SA.11?
Posted on June 12, 2017 at 17:05
none
#tls-spwf01sa.11 #data-lost #large-data #spwf01sa.11
    Gerardo GALLUCCI
    Jun 12, 2017 3:40 PM UTC
    Posted on June 12, 2017 at 17:40
    Hi Jean,
    problem is that, if you want to receive X bytes, you need to store (in worst case) 2X bytes. Record is not decrypted if it's not fully received. There is an alloc/realloc mechanism inside.
    Module has 64KB RAM to run everything, including filesystem (if any), TLS (if used), webserver (if clients are in), etc. Check 'AT+S.STS=free_heap' after WIND:24.
    Basically, using a standard SPWF01S FW, cannot receive all of this amount of data over TLS. Use HTTP1.1 header capability to ask for smaller chuncks (Content-Length / Content-Range). Ask for a customization to your ST distributor/reference.
    Alternative option: move to SPWF04S
    jerry
