Oct 16, 2023 1:25 PM UTC
VNH5180A-E
i have buy VNH5180A-E powersso-36 tp pakage some 20pcs but i check measurement not as per datasheet
can you let me know
dimension A /a2 = 2.53 mm  as per our  ( as per datasheet is 2.15-2.47mm)
dimension H = 9.91 mm as per our ( as per datasheet is 10.10-10.5 mm)
dimension D = 10.50 as per our ( as per datasheet is 10.10-10.50 mm )
