Visitor
Sep 19, 2026 3:24 PM UTC
Values for S2-LP design at 433 and 868Mhz (Different build options)
Trying to update an existing design to use S2-LP , but I need table of values for 433 and 868Mhz operation. This needs to be one pcb layout that can be populated for either frequency. I have searched through the website but I can’t find a solution. I have found a eval board for FKI433V2 @ 433 Mhz, but no equivalent for 868Mhz. The other 868Mhz boards use a balun, so the layout would be quite different.
I’m sure many people have gone down this route in the past.
Nov 5, 2026 1:10 PM UTC
Actually the 868MHz SMD variant does exist : https://www.st.com/en/evaluation-tools/steval-fki868v2.html
Rgds
Ronan
