aj.sk
Mar 5, 2019 4:22 PM UTC
Using the BlueNRG with FreeRTOS
I try to use the BlueNRG in conjunction with the FreeRTOS but the system always ends up in a hardfault as soon as I querry the BLE services.
The initialization of the BlueNRG works and establishing a connection works as well. But it seems like any user driven event crashes something.
I have 3 concurrent tasks and the BLE task has highest priority.
My assumption is that I somehow have to implement an event driven scheduler blocking but I don't know where to start.
aj.sk
aj.skAuthor
Mar 6, 2019 12:44 PM UTC
Doubled the task's stack size, now it works
nfei
Mar 19, 2019 3:07 AM UTC
hello, i did a similar work and i found program will crash in hcl_tl_lowlevel_isr().
Do u have this problem?
aj.sk
aj.skAuthor
Mar 19, 2019 7:07 AM UTC
Do you have the EXTI interrupt enabled in CubeMX?
nfei
Mar 19, 2019 7:10 AM UTC
yes, i need the exti interrupt to achieve SPI packets.
