PVala.1
Oct 29, 2020 10:08 AM UTC
Usb Type C
We would like to use USB Type C PD chip for Data role or Power role swap functionality.
We are designing the android accessory using type c connector.
We would like to keep our accessory in Device mode and also want to do the charging of smartphone through type c connector.
Can you please suggest the chip which is required minimum firmware application and we can put the accessory in device mode with source power to smartphone ?
