USB-C with STUSB4500 - get power from laptop
Hello :)
This USB-C is confusing me. According the standard you should be able to receive or to send power. I am using the STEVAL-ISC005V1 Eval board form ST. Unfortunately the PD2 and the PD3 line is not active if I plug the device into a Laptop.
So my question: How to configure Windows to act as a power source?
A short google search showed always results about on how to load your laptop with the USB-C port but not on how to act as a 20V power source.
Is it possible to get 100 Watts out of a USB-C plug from a Laptop?
Thanks for you answers.
Cheers,
Chris
